crownvictoria31 Posted November 16, 2016 Report Posted November 16, 2016 Is a stock 200 amp alternator enough for a 2500-3000 watts RMS system enough? This is the stock alternator for a crown vic police interceptor.
reedal Posted November 16, 2016 Report Posted November 16, 2016 at idle, and possibly even at a higher rpm when full volume, you may experience some voltage drop, but having a second battery may help with that. Try it out, use a group 31 size battery as a secondary, and keep an eye on the voltage while listening. if you dip into resting voltage, then an alt upgrade is recommended in my opinion. people use stock alts all the time with more power, but they have a good battery reserve too, usually. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
