r.sok Posted November 21, 2016 Report Posted November 21, 2016 Am I supposed to mount it closest to my h/u and then do my rca run or after the long run of rcas and mount it near the amp
tdsa23 Posted November 21, 2016 Report Posted November 21, 2016 Close to your H/U XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
cdoubbbasshead Posted December 26, 2016 Report Posted December 26, 2016 I have a question. I have an eq/line driver with a master volume on it. Do I match my amps gains to the head unit of eq? If so do I max the volume on the eq and then set the head unit volume to 3/4 an set the gains from there?
reedal Posted December 27, 2016 Report Posted December 27, 2016 no. The 3/4 volume rule you see on yahoo answers and some other sites found on google is not what you should go by at all, ever.You use a tool that can detect distortion in an analog signal, measure the signal of your HU to find maximum distortion-free volume, then connect HU to EQ and adjust EQ output until you reach max distortion-free (unless the voltage goes higher than your amps max input voltage, in which case, back it down to that voltage), and then connect output of EQ to amp, and match amp gain to input voltage/measure the signal as you turn it up and stop when you see distortion. an O-Scope or DD-1 would be the tool you want to use for this. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
cdoubbbasshead Posted December 27, 2016 Report Posted December 27, 2016 Thanks for the info! I knew the 3/4 rule wasn't the best way to do it but at the moment I don't have an o scope. Thanks again!
