Need some clear answers for Ohm wiring please!
8zouci8
I just recently got a Hifonics Brutus Elite 2500.1D as a present. I am having issues trying to wire up my two 12" Apline SWR - D2's. They are the 2 Ohm DVC. I am trying to figure out how to wire them properly without causing damage to my amp. I have one sub jumping (-) to (+) then of the opposite coil. Then other 2 leads jumping to (-) (-) and (+) (+) to the other sub. That sub also (-) to (+) and the other 2 leads going to the box terminals. Which reads around 2.4 Ohms at the box terminals. But When I set my leads on the amp side It reads 1.4 Ohms. Is there a reason it's not reading 2 Ohms instead? I want to run at 2 ohms instead of 4 ohms. Or is something going wrong? I originally wanted to run the amp at 1 ohm but I know the 2 ohm DVC's can't go to 1 ohm it jumps to 0.5 ohms and the amp is not stable at 0.5 ohms. Could someone please explain the problem I am having if any?
What you wrote doesnt make sense.
Make it like this if its not already.
Hammerdown... 1%
That Is what I ment by the (-) and (+)'s. I have it wired like that and it reads 2.4 ohms at the last woofer but amp terminal reads 1.4 Ohms is that of any significance? Also that is how I have it set up.
you're not going to read an exact 2ohm, as the resistance will vary with the environment the sub is in. as for why you're reading 1.4 at the amp, you have the wires connected to the amp while you're checking it right? so you're now also reading the amp's resistance on the speaker outputs as part of the circuit.
Just play it. you're fine.
Thank you! All I needed was that explaination! Thanks bud! Still learning things here and there so I appreciate it! Thanks everyone for the fast and quick responses btw.
measuring at the last sub does not measure the entire circuit.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 2369 Guests (See full list)
