Jhensley209 Posted November 23, 2016 Report Posted November 23, 2016 I need some help with a slot port enclosure for a single sundown audio X12 V2. Its going in a 2014 dodge dart and it has more than enough trunk space
Triticum Agricolam Posted November 24, 2016 Report Posted November 24, 2016 What dimensions do you have to work with? What amp? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jhensley209 Posted November 24, 2016 Author Report Posted November 24, 2016 What dimensions do you have to work with? What amp?Its 36w by 16h by 18d and a ct sounds at1400.1
Joe X Posted November 25, 2016 Report Posted November 25, 2016 So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
