Okay 2 15" Fi BTL'S both dual 2 ohm voice coils. Lowest amount of Ohms amplifier can handle is 1-Ohm. Is it possible to wire amplifier to 1 ohm or do I gotta stick with 2-ohms?
Derp.
i dont think you can get to 1 ohm w D2 subs i could be wrong tho
i think D1 and D4 or something like that is it
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
The only .5 ohm amp I know is the model that mmats makes, but they dont make a 3500 watt rms one. They have a new 4000 watt amp out but its not 1 ohm and only compeitors can get it. You may have to stick with 2 ohm. Or you could take my suggestion which im doing. Strap 2 PA 3000ab's and get over 4000 watts rms at 2 ohm.
Okay is there a wiring configuration out there, or is it even possible to get a 1-Ohm load from, 2 dual 1-Ohm woofers? If possible please help me! :)
Derp.
Awesome!!! Thanks for that last bit of information. I wasn't totally sure if it could be wired that way. Again, thanks alot!!
Derp.
