WhiteMan_FTS Posted December 26, 2016 Report Posted December 26, 2016 Hi everybody. I listen to rap with low bass, and my head unit is at max(before it sounds like crap) at all times. I drive probably 3-4 hours a day. Previously I had a 94 towncar and the set up was 2 Alpine type r 12"s at 1 ohm Hifonics 1800 at 1 ohm 0 gauge power and ground Factory 130 amp alt and walmart battery At night time my voltage meter would sometimes drop town to below 12.5 and I know that that is not enough. I now have a 95 towncar. My set up is going to be 4 Alpine type r 12"s 2 hifonics 2400 amps 0 gauge big 3 upgrade 0 Gauge power and ground wired to rear battery 250 amp alternator (Will this be enough?) My questions are: Is 1 250 Amp alternator enough? What batteries would you recommend for under the hood and in the trunk? Optima yellow tops? Please keep in mind I am trying to keep this as affordable as possible.
s5300 Posted December 26, 2016 Report Posted December 26, 2016 I would seriously consider throwing an XS Power D3100 wherever you can get it to fit, and then you should be good.
ShadeTreeMechanic Posted December 26, 2016 Report Posted December 26, 2016 I would add two G31 batteries to the back. More alt is never a bad thing. Those amps are power hungry. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Jessica Posted December 26, 2016 Report Posted December 26, 2016 if you wanna save some coin you can go to remy battery and grab two of these http://www.remybattery.com/intimidator-9a34m-battery.html g34 AGM. very nice batt, has bolt down terminals for convenience. i was running two of these with a 240 amp alt and two 85.4's and 3k, now im running two with a 190amp alt and 1 85.4 and 3k. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
