Two box designs, Please help me decide!
jdjd
That JL box actually looks pretty cool. Never seen a box like that. I like the design where the sub and port face up. The angles on those boards may be a little tricky but hey, if you can do it then do it! My concern would be, like Triticum said, securing your box. If you can figure out a way, and I know you already said you did, to make sure that bad boy is 100% secure then I say go for it! Worse case scenario is you have to make another box because you don't like the way this one sounds as long as you don't blow this one!
I like the third design. Maybe even move it back so it sits against the seat back so it is close to the back window. With sub and port up, it would be able to load against the corner where the roof and window meet.
Pioneer 80PRS
I agree with ShadeTree's suggestion and would design the box so that it rests against the back of the seat. You could then fire the port up along the back of the box.
Builds:
Yea I'm leaning toward the third design also. Can't move it back cause I want to be able to hinge down the cup holders that are in the center. I'm concerned with the overall sound but I want my truck fully functional. Do you think it would sound better if I made the overall size larger to the specs of the second design? 6.21cf.
Sounding better is up to you. It would be a more peaky response. Some people like that and some people don't. To get a better idea of what it will sound like, you need the net volume, not the gross volume. Net volume takes into account driver, bracing, port and misc. displacements. It's the total air space that the driver will see when everything is said and done.
I wouldn't worry about making it any bigger. That's the least of your worries with the sub and port in the middle of the truck. I would just keep the old setup. You are splitting hairs that become moot, given the compromises being made. You might not notice much of a difference no matter what you do. Interested to see how it turns out. Just my two cents worth.
Pioneer 80PRS
Thanks for the replies as it really helps to hear from people who have been around this for a while. If I made it like the larger design the net volume would be: 4.15cf and if I make it the smaller design the net volume will be 3.56 cf. This is after driver ,port, and all bracing. So which do you think would be best and why? I originally chose the larger design because the net volume would be right in the middle of what AA recommends:3 to 5 cf. Please explain what you mean by peaky. The JL setup I had in there seem to blend with my front stage pretty good but was just lacking overall punch and volume. I don't mind my bass to boom a little. I want to know my bass is there. I think the JL enclosure ended up being a little smaller than what JL recommends so I was hoping to make this set up sound better and get louder. I just never felt the JL setup ever moved much air.
By peaky I mean that if you're looking at a frequency response graph there will be a visible peak in response. This equates to the sub being louder at that peak but keep in mind that cabin gain can change it depending on where the peak is and where your cabin peaks at. If you're really indecisive, you could always make the larger box, and, if you don't like the way it sounds, try and take up internal space. Would be a pain in the ass but you could go that route if you wanted.
  • Who's Online   0 Members, 0 Anonymous, 542 Guests (See full list)
