Which amp is the best bang for my buck
Joe Hagerty
Skar doesnt have a ph2000. They do have the rp2000.1. Solid amp. Does rated. Your thinking of the american bass ph4000.1. Also a solid amp that does rated. Either one would be a good choice. Buy one now then another later and strap them.
If theres any way you could wait and save a bit more, The Incriminator amps do way over rate on output.
The IA 20.1 is a bad mofo.  they are well made and run over rated power.  That one is rated for 2800w rms Mono.
on SMD's Amp Dyno test it did 2640W Certified @ 1 ohm, 3607 uncertified @ 1ohm, and 4197w Dynamic @ 1ohm.
This amp is a BEAST!
might need two 1/0 Cables just to give it enough power.
http://www.incriminatoraudio.com/index.php/products/amplifiers/ia20-1-mono-block.html
FOr a better budget friendly solution, you could get 2 NVX JAD 1200.1 amps.  Run one on each speaker.  you will just have to make sure you tune the outputs perfectly so the speakers dont fight each other.  At $199 per amp, its a damn good solution for your application.  These NVX Amps did great on the dyno as well.
  • 4 weeks later...
And a versus thread
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1034 Guests (See full list)
