Michael Dean Posted January 2, 2017 Report Share Posted January 2, 2017 Does any one have any experience with this amp claims 2000@1omh new 399$ I can get a used one for 240 What do you think of this amp? Synergy Audio WFO 15.1D 2,000w RMS Mono Block Continuous Power Output @ 14.4V Input RMS power @ 4 ohms mono: 650W x 1CH RMS power @ 2 ohms mono: 1,200W x 1CH RMS power @ 1 ohm mono: 2,000W x 1CH RMS power @ 2 ohms linkable/dual mono: 4200W x 1CH Signal to Noise Ratio: >100dB Low Pass Frequency Crossover: 30Hz~250Hz Subsonic Filter: 10Hz~60Hz Bass Boost: 0~12dB Bass Boost Frequency: 30Hz~90Hz Phase Shift Control: 0~180 degree Frequency Response: 10Hz~350Hz (+/- 1dB) T.H.D. Continuous @ 4 ohm/100Hz: <0.15% Efficiency @ 4 ohm/100Hz: 90% Input Sensitivity: Variable 200mV~8V (+/- 5%) Dimensions (mm): 430(L) x 230(W) x 58(H) Operating Voltage: DC 8.5V~16V Recommended Fuse Rating: 200A (linked: 400A) Wired remote bass level control Link to comment Share on other sites More sharing options...
ToNasty Posted January 2, 2017 Report Share Posted January 2, 2017 Good amp. Had one of the first ones. Worth the money ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
