AGuyWithAJeep Posted January 4, 2017 Report Share Posted January 4, 2017 My Rockford T2500bdcp is about 5 months old. Recently the voltage meter on the amp is consistently at 11.1 volts. Truck I should 14.6-14.7 constantly. I have a Mechman 370 amp alt, Big three, XS D3400 under the hood and another XS D3100 in rear. All wire is 0 AWG Sky High. At full tilt the lowest I saw was maybe 13.6 volts. Subs are wired to one ohm. None the less though, has anyone else experienced this issue before or have any thoughts on what it could be? I have a digital volt meter wired directly to the D3100 in the rear, which is the same battery the T2500 is connected to. Digital meter and DMM say 14.7 volts at battery, but amp says 11.1 on meter on amp. It still works, but isn't drawing power like it should, nor is it nearly as loud. Currently not using it to prevent further damage. Also All connections seem good and tight. No blown fuses. Etc. please help. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted January 4, 2017 Report Share Posted January 4, 2017 is there a fuse between the rear battery and the amp? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
AGuyWithAJeep Posted January 4, 2017 Author Report Share Posted January 4, 2017 Yes, it's not blown nor is it loose in connection. Power and ground are 0 gauge and about 2 feet long Link to comment Share on other sites More sharing options...
06RTCharger Posted January 4, 2017 Report Share Posted January 4, 2017 If ur readings at the battery are great, but low on the amp.....something is happening along that connection before it reaches the amp. Assuming the amp isnt bad its self. Maybe take a volt meter and take a reading from the exact end of the wire that u connect into the amp. If its reading low on just the wire then ur wire run is definatly compromised. If thats the case, maybe Inspect ur power wire run all the way from the battery to ur amp. Check for corrosion/discoloration at every end that has a lug/terminal on it. Could be a bad crimp/solder. Could be low quality wire, ive seen a few people having issues with that brand of power wire. Goodluck man. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted January 4, 2017 Report Share Posted January 4, 2017 Check voltage on the amp side of the fuse. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
AGuyWithAJeep Posted January 4, 2017 Author Report Share Posted January 4, 2017 Voltage going into amp is good, grounds are all good. I just disconnected everything from the distribution blocks, sanded and rebolted to make sure it all had a good connection. No issues there. Sadly I'm assuming it's the amp at this point. The more it is on, the worse it gets. It's starting to show red now and is at 10.4ish. Won't even play most music with bass knob all the way down. Link to comment Share on other sites More sharing options...
AGuyWithAJeep Posted January 4, 2017 Author Report Share Posted January 4, 2017 Also all connections are soldered, I don't believe in using crimps. Did once many years ago, never again. Link to comment Share on other sites More sharing options...
06RTCharger Posted January 4, 2017 Report Share Posted January 4, 2017 Time to for a new amp then. Link to comment Share on other sites More sharing options...
AGuyWithAJeep Posted January 4, 2017 Author Report Share Posted January 4, 2017 That's what i was thinking but hoping it could have been something else. Atleast it's still in warranty... I wonder what could have caused this though. I've never really had any problems with RF products, hopefully this was just a defect in this amp. Link to comment Share on other sites More sharing options...
Chase Wallace Posted January 4, 2017 Report Share Posted January 4, 2017 Out of curiosity could you let us know how the warranty process goes? For what those amps cost I would hope they would just send you a new one right away but I'm curious as to how long they take and if they give you any trouble. Link to comment Share on other sites More sharing options...
