New CC-1 user here! The instruction states to set the volume at 0 and then gradually turn it up until the green signal light goes on.
However, when I was doing it, I already had it somewhere under my max clean volume.
I initialized the CC-1 and the green signal light would go on and I would just hit read and adjusted my HPF on the amp until the blue calibrated light goes on.
Is it ok to do it this way? It won't set my frequency at some weird number?
I'm assuming the instruction just says to have it at 0 so that users don't break their equipment by turning the CC-1 on and go into a giant clipped signal...
Thanks in advanced!
Try it both ways and see if there is any difference. Then you can let me know because I have always followed the directions.
Pioneer 80PRS
  • 8 months later...
In his video's, Steve explains you need only a very low volume. I believe as long as the signal LED stays green and doesn't turn red you're good.
I've seen him set his head unit to 10 to gain/crossover match a bunch of amps. You just turn the volume to a safe level and you should be good to go.
