Project "Smallest cone area hairtrick ever" has begun!! Only 2 8" subs doing +144 dbs @ 35 hz!!
oh yeah it is!!! gonna post the pics of the wiring and maybe some vids tomorrow, car is doing over 144 at 35 hz and yes, im pretty sure i can hairtrick with it with some more tweaks and testing!
took out the Tiny ass stock battery!!
Wiring everything, once again, soundquest CCA wire, one run of positive and a run of negative directly to the back.
6B32E606-2106-453D-81B6-38AC13E4CF08_1.j
Same wire used to make the big3
Wires done!!
Single SPV35 battery, biggest i could fit in the stock location, should be enough for the amount of power i´m gonna be using... i hope!!
1055CB40-240A-4AE3-9145-F28E7613D14E_1.j
Fired out for the first time few days ago, subs already broke in, car is definitely nasty for the amount of equipment i'm using, just need to fix a couple of minor tweeks and should be able to try a hairtrick, bandwith goes from about 27 hz to 60 hz so the car plays flat as hell , peak frequency seems to be around 37 hz and about 32-33 hz is where it's moving more air...
this just happened!!!
17796510_10154797311978300_1598401143301
thanks a lot bro, glad you like it!
