Blake21 Posted March 31, 2017 Author Report Posted March 31, 2017 So I'm probably smell my amp and not the subs?
ShadeTreeMechanic Posted March 31, 2017 Report Posted March 31, 2017 32 minutes ago, Blake21 said: So I'm probably smell my amp and not the subs? if you smell your amp then its toast. if the amp still works then it is the subs. Subs will get smelly when they are being clipped by the amp because it is hard on them. if your subs are getting smelly then turn the volume down a little and let them live. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Blake21 Posted March 31, 2017 Author Report Posted March 31, 2017 Ok, what's a good brand auxiliary cord
Blake21 Posted March 31, 2017 Author Report Posted March 31, 2017 Excuse the mess, I'm working on cleaning all this up just waiting on parts to get here
Blake21 Posted March 31, 2017 Author Report Posted March 31, 2017 Like I said excuse the mess, planning to have all this cleaned up in the next couple days
