Headunit skipping? ?
So when I get loud, real loud my music skips in and out, is it the headunit?  It's 2 hdc3 18s in a truck on a cheap 65$ pioneer headunit playing through auxiliary cord on youtube, it sound great at low volume but when I turn it up it cuts in and out, I'm guessing the entire head unit is skipping
Your sub amp will suck the power out of your front amp. If your voltage is dropping, maybe that's what is happening.
Pioneer 80PRS
So i ne ed more batterys?  Its only dropping to 11 which is low but I didn't figure it would cut off
How many batteries do you have in the back?
Pioneer 80PRS
None I've got two up front with a 250 amp mechman alternator with dual 1/0 wires goin to primary battery. I'm running a second run of 1/0 to the back this weekend, the amp gets wicked hot running at 1 ohm
Another thing you might want to do is check your wiring and see if it is getting really hot as well, if you can put one of those batts in back that might help with voltage drop.
If you have another H/U to try, i would do that and see if anything changes, or try hooking up a phone directly to the amp with an adapter.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Does it do the same thing with cd's? Maybe the aux/phone/youtube signal youre using is horrible and clips quickly. If the aux cuts out, but cd's play fine. Then maybe its just that u need to play better signals.
If your amp is getting that hot then you will end up killing it. Keep an eye on your voltage at the amp, you need to keep it up. Get a couple of G31 AGM to put in the back and go through the floor to the frame with the ground and make sure you have a big ground from the frame to the engine block and the front batteries to the block. Post some pictures of your setup if you can.
Pioneer 80PRS
Ok I'll be working on it shortly so I'll get some pictures, and order a new aux cord what's a good brand aux cord the one I have came from spinx
Unfortunately my hydraulic crimper and dual fuse block want be here until Monday so can't run my second run of 1/0 until then but I will change my ground today and try a cd
  • Who's Online   0 Members, 0 Anonymous, 837 Guests (See full list)
