Insaneclown623 Posted April 17, 2017 Report Posted April 17, 2017 i see Joe help a lot of people on here with they're boxs..... if he can do the same for me that would be great ..... im new to the box building and i have 3 of the rockford P2D2. amp size 1000x1 punch well add another 1000x1 amp if need ,,, have to save some money or end up buying a 2500x1 to power all 3 if it helps the box well be in the backseat of the car..n if you can make the front with a 45 degree so i can design around it and make it look like it belongs in the car Music '' Rock $ Rap " thanks
Triticum Agricolam Posted April 17, 2017 Report Posted April 17, 2017 What car do you have? What are the dimensions of the space you have available? Have you already or are you planning on removing the back seat to make space for the box? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Insaneclown623 Posted April 17, 2017 Author Report Posted April 17, 2017 Yes right now the plan is to remove the back seats and build a floor and back piece ....so the box has a place to seat and its level. when i get off work ill get some dimensions Car = 2000 Mercury Cougar " Hatchback "
Insaneclown623 Posted April 19, 2017 Author Report Posted April 19, 2017 On 17/04/2017 at 0:25 PM, Triticum Agricolam said: What car do you have? What are the dimensions of the space you have available? Have you already or are you planning on removing the back seat to make space for the box? External Height = 30 in External Width = 40 in External Depth = 19 in something like that with the port facing up to the roof or the side witch ever thanks for the help.
Joe X Posted April 19, 2017 Report Posted April 19, 2017 If it's a hatchback, most likely you likely are going to benefit with a subs up / port back or up configuration. Any pics of your trunk?
Insaneclown623 Posted April 19, 2017 Author Report Posted April 19, 2017 23 minutes ago, Joe X said: If it's a hatchback, most likely you likely are going to benefit with a subs up / port back or up configuration. Any pics of your trunk? the back seat will be remove and ill put in a floor where the bottom of the seat was and another one to the top/back of it in the truck i have all my amps . im not looking to go on the meter lol just a nice sounding box.
