j.c.b Posted April 28, 2017 Report Posted April 28, 2017 I need help designing a 6th orderbandpass for my 4 e15v2. It will be powered by cresendo bc3.5k @ 1 ohm. My car is a 98 4runner.and it have a 2 pcs d3100 batts on it.
Triticum Agricolam Posted April 29, 2017 Report Posted April 29, 2017 What's your reasoning for wanting a 6th order bandpass? What are your goals for the system? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe X Posted April 29, 2017 Report Posted April 29, 2017 Subs have an EBP of about 48 not sure if that's going to be adequate for a 6th bandpass.
j.c.b Posted April 30, 2017 Author Report Posted April 30, 2017 On Saturday, April 29, 2017 at 5:28 PM, Triticum Agricolam said: What's your reasoning for wanting a 6th order bandpass? What are your goals for the system? My friends told me that it will give a good lows on it. Daily use only.
j.c.b Posted April 30, 2017 Author Report Posted April 30, 2017 On Saturday, April 29, 2017 at 9:13 PM, Joe X said: Subs have an EBP of about 48 not sure if that's going to be adequate for a 6th bandpass. My sub wont work in 6th bp. How about 4th order? Planning to put it on 2ndrow. H=39 W=43 D=45
Triticum Agricolam Posted April 30, 2017 Report Posted April 30, 2017 3 hours ago, j.c.b said: My friends told me that it will give a good lows on it. Daily use only. Don't listen to your friends. Your best path to good low end performance is almost always a well designed and constructed ported box. Compared to bandpass boxes they are simpler, more forgiving, and take up less space. The subs you have are never going to be low end monsters that some other subs are, but if you put them in a large, low-tuned box with appropriate port area you will likely get the most out of them as possible. I'd shoot for 16 cu ft of net volume, tuned to 30 hz, with at least 180 sq in of port area. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
