yes :^...might wanna thow a fuse in there near the 1st battery, and maybe another after the 2nd battery depending on how close it is to the amp...
i likes me some audio stuff...
Guest MegaloManiac
yep. that wiring you just showed is in "parallel"...remember that term.
looks good.
run a fuse 3" form each battery POS(+)
So pretty much 1 fuse from the first to the second battery and then second fuse amps. Correct right? What do you mean by parallel? What amp fuse should I use when battery to battery?
Nismofreak School account.
Guest MegaloManiac
show off my mad skillz
if you were to wire the bats in "Series" youd get a 24V load(blow the sh!t out of your amps and whole electrical system)
in paralel you increase current while retaing voltage
Guest MegaloManiac
paralel is what you drew up.
Parele: pos to pos; neg to neg.........you still get 12v
Series would be: neg to ground; pos from 2st bat to neg on 2nd battery; and pos from 2nd batery to pos on amp and you would ground amp...24V load
  • Who's Online   0 Members, 0 Anonymous, 801 Guests (See full list)
