Grounding alt to chassis
I've been prepping the rear chassis for grounds as I will be grounding my amps and batt bank to the chassis back there.
So my question is, along with grounding the alt to neg. terminal under good, would I do my second alt ground to chassis under hood OR ground in the rear near the amp and batt bank grounds?
I would ground both the front and the rear. You will need both to complete the circuit.
Pioneer 80PRS
Gotcha, 1 to batt terminal underhood and 2 to chassis (front and rear). Thanks ShadeTree
I hope I didn't misunderstand your question. Just to be clear: you have the alt grounded to your battery. From this ground you need to ground to the frame up front. Then from the rear the batteries need to be grounded to the frame in the back also.
Pioneer 80PRS
Yeah, as of now, the alt has 1 ground run to the under hood battery. The under hood battery is also grounded to the block and to the chassis (2 runs per, all up front). I read a thread from 2014 regarding alt grounding and amps/batts in the rear that also included a YouTube vid that TonyD did. After it was all said and done, I am more confused than I was to begin with. Not sure if I need to do another ground run from alt to rear chassis or battery.
Generally speaking, a front to back ground run is only needed after two or three positive runs front to back. If you just have one or two positive runs, then the frame is the only ground you will need.
Pioneer 80PRS
Ok. So just to clarify, alt to chassis ground up front is all I need. And yeah, I got 2 positive runs going to the rear.
If your alt is grounded to the battery and your battery is grounded to the frame then you are good. You don't need the extra alt to frame ground but it wouldn't hurt anything.
Pioneer 80PRS
Awsom.Thanks for all great info
  • Who's Online   0 Members, 0 Anonymous, 4226 Guests (See full list)
