Rich Schenk Posted May 10, 2017 Report Posted May 10, 2017 Have a good idea on how to do this but would like input help pictures etc on how to go about this. Thinking cutting wood as big that will fit in between box and sides and roof attaching with screws. Also should this be double thickness or is single layer fine. Then putting some sort of caulk backing or weather stripping in between the wood and the roof and sides and caulking the seam to seal it up. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Rich Schenk Posted May 11, 2017 Author Report Posted May 11, 2017 Any pros who can help, advice etc??? On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
jk13 Posted May 11, 2017 Report Posted May 11, 2017 At the point of caulking to the headliner it's going to be ruined anyway. What's the goal? Removable with no damage or just a clean and sealed off install? If you're not chasing tenths I'd just build the trim piece out of 3/4" and wrap it in carpet or whatever material you're matching. We've even used carpet as a padding/flex-fit layer and wrapped the finish material over it (suede or vinyl etc.). Make sure it's a good tight press fit everywhere then mount it to the box. Remember too that once the box is slid into place you can add side mounting points if you have access. Make sure they're removable to slide the box back out. Static drops are my bag.
