Harald Vegsund Posted May 22, 2017 Report Posted May 22, 2017 I recent purchased this sub(Identical to TC Sounds TC3000) and I would love to get some help with enclosure design(Joe X, Triticum??). Im powering it with a b2 MA2000.1. My dimensions are; 38 inches wide, 18 inches tall and 18 inches deep. I can go taller and deeper. All of this is going in the trunk of a Golf MKV. This is the specs I have managed to get of the sub; *Re: 4.7 ohms (series) *Fs: 22 Hz *SPL: 87.4 dB 1W/1m *Magnet weight: 225 oz *CMS: 135 uM/N *Mms: 390 g *BL: 26.2 Tm *Sd: 0.082 sq. m *Vas: 4.45 cu. ft. *Qts: .40 *Xmax: 30 mm *Dimensions: Overall diameter: 15.51", Cutout diameter: 14.02", Mounting depth: 9.48". Parameters 12″...............................15″ Qts 0.33.............................................. .......0.40 Re (series) 4.7 Ω................................................. ..4.7 Ω Fs 25 Hz................................................ ...22 Hz Cms 125 µM/N............................................. 135 µM/N Vas 44 lit............................................... .....126 lit Mms 310 g................................................. ..390 g BL (series) 26.2 Tm...............................................2 6.2 Tm Sd 0.050 m²..............................................0. 082 m² SPL 85.2 dB................................................ 87.4 dB Specifications Voice Coil Configuration D2 | Q1 Ω........................D2 | Q1 Ω Mounting Depth 7.99″................................9.48″ Driver Cutout Diameter 11.16″..............................14.02″ Overall Driver Diameter 12.60″..............................15.51″ Magnet Weight 225 oz.............................225 oz Driver Weight 44 lbs...............................46 lbs MSRP $749.................................$849 PerformanceBL²/Re 140 N²/W.........................140 N²/W Xmax 30 mm.............................30 mm TLS: < 1% BL deviation 14 mm.............................14 mm Recommended Amplification 2500 W RMS.................2500 W RMS 4th order reflex enclosure volume 1.2 - 2.1 ft³..................3.0 - 4.2 ft³ 2nd order sealed enclosure volume 0.6 - 1.4 ft³..................2.0 - 3.8 ft³
ShadeTreeMechanic Posted May 22, 2017 Report Posted May 22, 2017 Internal port or external? @JoeXxxrwsd @Triticum Agricolam Is that the right joex? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Harald Vegsund Posted May 22, 2017 Author Report Posted May 22, 2017 Internal. Was thinking sub and port up or back.
