XS Power
From the xs pdf
It is very important that proper charging techniques be used when charging AGM batteries. AGM
batteries are designed for use with AGM battery chargers with a MAXIMUM output voltage of 2.4 volts per
cell(14.4v for 12v batteries and 19.2v for 16v batteries). AT NO TIME during charging should the battery be
subjected to more than 2.4 volts per cell. Voltage above this will cause the battery to “gas” and once
oxygen is vented it cannot be restored.
 Maximum charge voltage
32f = 15.3v / 50f = 15v / 68f =14.8v / 77f = 14.7v / 86f = 14.5v / 104f = 14.3v
