Rybass Posted June 14, 2017 Report Posted June 14, 2017 Well I tried to make this easier by adding a blueprint i made, but even the smallest setting on my phone makes the file to big. Anyway I only have a phone, so i had to do everything the old way. Im doing 2 sa 10's tunes to 33hz, not a big trunk so im going with tens. I need to do a 3inch wide port to make it work, so u think I'll get port noise that small? This is what i came up with using a calculator and re Port 12.5h×3w×25.88L 33hz Port area 37.5 Port volume.842 Sub disp is.11 each. Gross volume 4.062. Net volume 3ft Box is 32w×14h×20d. Shared port in the middle of both subs Had to do it all by hand subtracting port displacement and all that, i calculated the port volume adding the wood thickness in the width, hope thats correct Thanks guys, not tryin to noob ya, but i wanna get this right
06RTCharger Posted June 14, 2017 Report Posted June 14, 2017 If u have an iphone, use the imgurl app to post pics.
Triticum Agricolam Posted June 14, 2017 Report Posted June 14, 2017 How much power are you going to run? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Rybass Posted June 14, 2017 Author Report Posted June 14, 2017 Im running a 2,000rms, but even with big 3, im gonna have voltage issues till I get the second batt, so it will prob be 1500-1600 real world
Rybass Posted June 14, 2017 Author Report Posted June 14, 2017 Btw I love your pics of the past builds 165db....hope eventually i can do advance calculations for boxes like the first two pics
Triticum Agricolam Posted June 18, 2017 Report Posted June 18, 2017 On 6/14/2017 at 5:59 AM, Rybass said: Btw I love your pics of the past builds 165db....hope eventually i can do advance calculations for boxes like the first two pics I'm glad you like my work! Sorry I haven't gotten back to you earlier. Your port area is a bit small, you will probably have port noise and will lose some output due to port compression. If you widen your port from 3" to 4" wide that should give you enough port area. You will need to lengthen the port to 35" to keep the tuning the same and increase the depth of your box a couple inches to make up for the lost space. Here is my suggestion: "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
