so i decided to do some hypothetical math.
i need 1000 watts for my subs and my normal pounding voltage is about 14 so.....
I x 14 = 1000 therefore 1000/14 = 71.4 amps
thats good and all except for the fact that my power wire is fused at 40 amps and i have never blown it so....
40 x 14 = 560 watts
in this perfect hypothetical situation im gettin at most 560 watts to my subs
this doesnt sound right at all. wut am i doing wrong or am i right just mistaken about sumthin?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
are you sure your amp is rated at 1000W RMS and not max?
its supposed to be rated 1100 wrms at 4ohms but i figured it wasnt
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
what kind of amp do you have? this sounds fishy
pa a3000db
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
My power wire is fused (Circuit Breaker) at 150amps. Although it should be 100a.
I have yet to blow that and my amp is rated 1500w R.M.S.
100% efficient amp at 14.4v
14.4v x 100a = 1440w when the fuse blows.
Now it is set to 2000w when It will blow.
No amp is 100% efficent.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
thats the thing that really scares me
cause in an absoulute perfect situation the most power i can get is 560 watts and i need 1000
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
That amp for me took some serious amp draw from my electrical system, I couldnt run it with out a second battery...
sure it says 40amp, not 80 amp?
but again, if your looking at 1100rms, your running it at 4ohms.
That amp is a serious amp, dont let the name fool you, same amp board as in Planet Audio, Soundstream,, and like 4-5 other amps
