thats the thing that really scares me
cause in an absoulute perfect situation the most power i can get is 560 watts and i need 1000
Then you need a new amp bro.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
how is your head unit driving your amp do you know? maybe your output power is low because you're input voltage is too low
Actually i cant say there isnt because there is one amp but zapco has it in a plexi, bullet proof shell with all vin and seriels scratched off of it.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
That amp for me took some serious amp draw from my electrical system, I couldnt run it with out a second battery...
sure it says 40amp, not 80 amp?
but again, if your looking at 1100rms, your running it at 4ohms.
That amp is a serious amp, dont let the name fool you, same amp board as in Planet Audio, Soundstream,, and like 4-5 other amps
im not talkin about wut the box says
i have my power wire fused at 40 amps and i have not blown it yet
and i have the gains just a hair over half up
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Or I have low gains?
Who knows.
I can hear slight clipping if I turn the gain up one more notch.
This all resembles to meglo test he just did about under powering.
You CAN NOT blow a sub from less power. The sub blows from clipping from the amp or the hu.
Get a bigger amp and milk the gains a lil and your fine.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
What amp is this?
Amp- Us-Amps M2D2
Have you had enough
I will be the one
