Kelz619 Posted June 18, 2017 Report Posted June 18, 2017 I was reading online a guy bought a sub that was too big for the box so he used a spacer ring so it'll fit. I get that part. Does a spacer ring do anything else? Does it change the displacement of sub and make the internal volume bigger? For example this box has 2 cub. feet after displacement and now 2.2 with a spacer ring?
Triticum Agricolam Posted June 18, 2017 Report Posted June 18, 2017 Its going to increase the box volume, but its going to be by a very small amount. Just how much depends on the dimensions of the spacer ring, but its going to be a small enough change that it will be inconsequential. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Charles Phillips Posted June 18, 2017 Report Posted June 18, 2017 By lifting the sub up with a spacer ring, you gain a tiny amount of box volume. Probably nothing lifechanging unless it's in a bandpass in which case it might screw the ratio up. - 2009 Toyota Matrix Base - - iPad 64GB - - miniDSP 2x4 HD - - PPI Art a200.2 - - SoundQubed SQ-2200.2 x 2 -
Jessica Posted June 18, 2017 Report Posted June 18, 2017 chances are, if the sub wont fit in the box, a spacer ring is not the answer. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Kelz619 Posted June 18, 2017 Author Report Posted June 18, 2017 So it really serves no purpose at all
Triticum Agricolam Posted June 18, 2017 Report Posted June 18, 2017 18 minutes ago, Kelz619 said: So it really serves no purpose at all Their purpose is to make a sub fit in a box it otherwise would not, which is a pretty important purpose when you need it. Other than that, it's a ring of wood, what are you expecting it to do, add 10 dB? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Kyblack76 Posted June 18, 2017 Report Posted June 18, 2017 Thats what i was gonna ask,... what are you expecting from a piece of wood ??? Imma lil lost. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted June 18, 2017 Report Posted June 18, 2017 Also, im lost on "it was too big to fit, so he used a spacer"..... Id think if it was to large, you would be removing material, unless it was to LONG, and needed to be lifted off the baffle to not hit the rear wall or some shiz...... Normally, its to fit a smaller dim driver, into a larger cut out.... im lost errrrrrywhere.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Jessica Posted June 18, 2017 Report Posted June 18, 2017 How I feel too Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Kelz619 Posted June 18, 2017 Author Report Posted June 18, 2017 42 minutes ago, Triticum Agricolam said: Their purpose is to make a sub fit in a box it otherwise would not, which is a pretty important purpose when you need it. Other than that, it's a ring of wood, what are you expecting it to do, add 10 dB?
