Mechman Alternators
S Series 240A (replaces L mount CS130). Part #B81657240P
A nice shot of the S Series 240A (replaces L mount CS130). Part #B81657240P
http://www.mechman.com/alternators/aftermarket-bracket-applications/s-series-240a-racing-alt-replaces-l-mount-cs130-polished-finish/
Description: This custom designed housing directly replaces standard CS130 "left mount" alternators as used on 1987-1995 Chevy C1500 Pickups and some aftermarket accessory drives. A side output stud and seamless rear cover with no plug opening allow for better clearance from the back of the alternator to the front of the engine and a smooth appearance. A "one-wire" self exciting internal voltage regulator makes installation of these alternators on older or customized vehicles a snap- Simply run a properly sized positive and ground cable from the alternator to the terminals of the battery and the alternator will work perfectly, regardless of what kind of wiring harness you have. Because of their compact size and standard GM mounting ears, these alternators also work well in many aftermarket or custom bracket installations.
Looks Nice!!!!!!  ??
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
