I know this is really simple but I just can't remember. Anyway I have a prime 400.4 in an accord powering the front components and the rear channels go to a dual two ohm sub. One channel per coil. So when you turn the key on it clicks. What's the remedy for that? Thanks.
On 6/25/2017 at 11:46 AM, reedal said:
What's clicking? Going strictly from the only sentence that mentions clicking, you'd be referring to your key.
Ok yeah probably could of explained that better. When I turn the key on and the amp turns on it sounds like it sends a signal and causes like a click. Like almost a pop. It also sounds like it mostly comes out of the tweeters.
On 6/25/2017 at 8:24 PM, 8ten8 said:
Do you have a turn-on relay? Maybe your hearing it open and close. Not a big deal
I do not. Just used the head unit remote wire since it's just one amp and not a whole bunch of stuff right now.
Where is head unit grounded, and where is amp grounded?
For the amp I pulled up the carpet in the trunk and grinded the paint of and drilled two holes and screwed my wire end to that. It's not like a six inches away from the amp input. The head unit is wherever Honda had the original ran. I just cut the wires and soldered them to the kenwood plug.
19 hours ago, reedal said:
That's not a good ground for your amp. You need to solder or crimp a lug on the end, and bolt it to the chassis. The body isn't a good return path.
I worded that weird again. I do have a lug on it and put the screws through the lug itself. Three to be exact. Would it trying to pull that ground cause the clicking?
Sometimes when you don't have a ground that connects back to the same point the source is grounded, you can get a turn-on/off pop. Having all chassis grounds provides all the same ground location (even if different locations on the chassis), and the chassis is a much better ground than the body due to its thickness.
