40 minutes ago, XPLODR said:
It's gonna be 42x35x28
Using aeroports and it's gonna be a simple double baffle flat wall.
Assuming you are going to use a double layer everywhere, you are looking at probably five 4'x8' sheets.
Builds:
Theres an iphone app called cut calculator which will help you figure it out quickly.
Orrrrr you could simply do it on paper and figure it out from there.
Its VERY simple stuff man.
BTW what are the rest of the specs on the wall?  And what gear are you using?  Personally I dont like building a wall with aeros, I find it to be a huge waste.
Tops and Bottoms- (4) 42x25
Sides                   - (4) 32x25
Baffles and Backs - (4) 42x35
This is doing everything the extremely simply way..double layer everywhere.  Double layer baffle only.|
18.05 cubic feet gross
Ends up requiring 5 sheets of 4'x8' material for that enclosure.  And you'll have a just under 70" of material left on your final sheet.  So you could make a third baffle layer with that if you wanted.
BUILT NOT BOUGHT
********LOOKING FOR NEW GROUND POUNDER TO BUILD********
1981 Malibu Wagon - Iron Block LS, Single Turbo, Nitrous, 6 Speed, Pump Gas, street car. --UNDER CONSTRUCTION
Goals are to make 1000 rwhp and 9 second quarter mile
1997 Explorer 157.8. Street C 2nd place 2007 San Mateo dbdrag world finals. (totalled)
  • Who's Online   0 Members, 0 Anonymous, 1181 Guests (See full list)
