josh19866914 Posted April 28, 2008 Report Posted April 28, 2008 what amp(s) would u guys recommend to push (4) Boston SPG555? http://www.bostonacoustics.com/car/car_pro...;product_id=373 currently im running them off of (2) RF T1000bd's @ 1 ohm.... 2000 Toyota Tacoma Prerunner SR5 (6) Boston 6 1/2's (4) Boston SPG555 (2) Rockford Fosgate T1000 (1) Rockford Fosgate T400
josh19866914 Posted April 30, 2008 Author Report Posted April 30, 2008 bump^ 2000 Toyota Tacoma Prerunner SR5 (6) Boston 6 1/2's (4) Boston SPG555 (2) Rockford Fosgate T1000 (1) Rockford Fosgate T400
2000s-10 Posted April 30, 2008 Report Posted April 30, 2008 Whats the rms on them and what ohm are they. i looked on teh link and couldnt find the rms. 1999 grand prix gt kenwood x994 head unit 1/0 big 3 all shok industry single run to the back New mid/highs coming not sure what Soundqubed q2200d at .5 (have) 2 soundqubed hdc3 12s (have) New box to be built.. sealed firing forward (yet to be designed) 200 amp alt not sure exact size or manufactor xs power batts
josh19866914 Posted April 30, 2008 Author Report Posted April 30, 2008 Whats the rms on them and what ohm are they. i looked on teh link and couldnt find the rms. Nominal Sd 555cm² Rated RMS power handling 1000 watts Nominal Impedance 4-ohm/ 2-ohm Mounting Cutout Diameter SPG555 Cutout Template Mounting Depth 8-1/4" (210mm) Linear Excursion 3-3/4 inches Recommended Enclosure 1.0ft³ (28.3L) volume sealed * 555 cm2 of surface area * 3¾ inches of peak-to-peak excursion * 3½ voice-coil * Radialvent® cooling technology * Only 26 Lbs! Thanks to Neodymium Lightweight design * RVC™ (Removable Voice Coil) allows coil to be exchanged without removing the woofer from the enclosure * SPS™ (Soft Part System) removable assembly enables field repair of the cone/surround/spider assembly * Can be field-stripped and custom painted, powder-coated, or plated * Work in multiple enclosures, both sealed and ported * Integral sealing gaskets simplify both standard and inverted mounting * Available in 4-ohm and 2-ohm versions 2000 Toyota Tacoma Prerunner SR5 (6) Boston 6 1/2's (4) Boston SPG555 (2) Rockford Fosgate T1000 (1) Rockford Fosgate T400
josh19866914 Posted May 1, 2008 Author Report Posted May 1, 2008 bump^ 2000 Toyota Tacoma Prerunner SR5 (6) Boston 6 1/2's (4) Boston SPG555 (2) Rockford Fosgate T1000 (1) Rockford Fosgate T400
Decaf Posted May 1, 2008 Report Posted May 1, 2008 a t4k would be sweet, and take up about the same space as two 1000s side by side
