2002 f150 stock frame to motor ground location?
If u could add a ring terminal mounting location to the rear housing of ur alternator, u could just ground the alt directly to the frame. The reason for upgrading the engine block-to-frame ground wire when doing the "big 3" is so that ur alternator has a better ground run. Grounding ur alt straight to the frame would be a lil better then grounding ur alt thru the actual engine block and then thru the engine blocks ground wire. Upgrading the engine block ground wire would still be a good idea just to have a better ground for ur motor and all its electronic parts to run thru. Better grounds are always good. U could do the alt ground now since ur in a rush. Then u can take ur time finding the stock grounds and upgrading them. Some engines could have multiple lil ground wires for different electronic parts.
  • Who's Online   0 Members, 0 Anonymous, 940 Guests (See full list)
