YukonXL04 Posted July 20, 2017 Report Posted July 20, 2017 1 hour ago, notorious97200 said: That's what I would do. I'd try 2 (max 2.5) cu Feet : that should be enough. That's what I was figuring. 2-2.25. But I'm not familiar with that sub 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
IKnowImLost224 Posted July 23, 2017 Author Report Posted July 23, 2017 Would a 6" aero be enough? Or what kind of port area would I be looking for with a slot port?
YukonXL04 Posted July 26, 2017 Report Posted July 26, 2017 Well you can break out winisd and model and see what the port velocity is looking like with a single 6". With that much power, in a small box, it's going to be a pain to get proper port area, always is with high power, and small boxes. 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
IKnowImLost224 Posted July 26, 2017 Author Report Posted July 26, 2017 1 hour ago, YukonXL04 said: Well you can break out winisd and model and see what the port velocity is looking like with a single 6". With that much power, in a small box, it's going to be a pain to get proper port area, always is with high power, and small boxes. With an Aero what kind of velocity would I be looking to be around?
YukonXL04 Posted July 26, 2017 Report Posted July 26, 2017 6 minutes ago, IKnowImLost224 said: With an Aero what kind of velocity would I be looking to be around? 32 meters per second for minimum port area, 22 for optimum. I generally just stay under 30 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
IKnowImLost224 Posted July 26, 2017 Author Report Posted July 26, 2017 Okay thank you sir. With WinISD is power taken into effect? I remember trying to model a setup before and didn't see any change when I added the power
Triticum Agricolam Posted July 26, 2017 Report Posted July 26, 2017 30 minutes ago, IKnowImLost224 said: Okay thank you sir. With WinISD is power taken into effect? I remember trying to model a setup before and didn't see any change when I added the power Yes, WinISD takes into consideration input power. You have to put in your input power for the port velocity graph to have any relevancy. The graph you want to be looking at is "Rear port - air velocity". "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
YukonXL04 Posted July 26, 2017 Report Posted July 26, 2017 Also if you input 3000w it might show high velocity. But realistically will you ever see a true 3000w with impedance rise and vehicle electrical taken into account? Most likely no so try a more realistic power input number 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
IKnowImLost224 Posted July 26, 2017 Author Report Posted July 26, 2017 Okay thank you guys very much for the help! If port velocity looks okay are there any other numbers I need to look at to make sure its enough but not too much port area?
