Triple Chamber 4th order
77-AUDIO
Anyone with experience in 4th order enclosured please help.
 I have designed this box for 4-10" db drive ewx
front chamber that will be the middle is 1.151^3
rear chamber on each side will be 2.0827^3
port diameter 8"
port length 25"
tuned (FL) 28.89
Tuned (FH) 86.12
 if this looks good let me know, if not please advise.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
So you are looking at about 4 cubic feet total for the sealed chambers and about 1.1 cu ft total for the ported chamber, is that correct?   Those numbers would be pretty unconventional for a car audio bandpass box.  Usually the ported chamber would be much larger than that.
How much power are going to be running?  Do you have any specs on your subs?  I hit google up but I wasn't able to find anything.
Builds:
i know it sounded weird to me also  i thought the normal rule of thumb was 2/3 middle chamber and 1/3 for each sealed chamber.  since it will be 3 chamber.  the 1/3 will actually be 1/6.
sub specs  Power for now will be a 1250.1 A7M  but plan on getting another one or a larger amp like a DC 2.0k to 3.5k.
Resonant Frequency (fs) : 41.9Hz
DC Resistance (Re) : 7.2 Ω
Mechanical Q (Qms) : 6.43
Electromagnetic Q (Qes) : 0.78
Total Q (Qts) : 0.70
Compliance Equivalent Volume (Vas) : 12.3
Mechanical Compliance of Suspension (Cms) : 0.06mm/N
BL Product (BL) : 23.6 N/A
Diaphragm Mass inc. Airload (Mms) : 229.1 gr
Sound Pressure Level (SPL) : 82.5dB
X-Max : 16.76 mm
If this dont work out I might just wall my kia soul c-pillar and just port that hoe out the top.  and go with 6-10" subs.
PPI dbl din
DC Level 3
DC audio 2.0k
  • Who's Online   0 Members, 0 Anonymous, 2045 Guests (See full list)
