Is there a grommet or a easy access spot to run grounds from the interior to the gram in a 07 Yukon class.?? Thanks in advance.
I've never owned a yukon but I would pull up that carpet and see for yourself.
Most likely near the wheel well or if there are strap anchors they would probably be close to those.
There are people on this forum with that truck so someone might chime in..
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
Second Skin
^^^ Build ^^^
Thank you for the tip!! I will check when I get my truck back!
In my Tahoe, there are no grommets behind the firewall that I found when I gutted the interior. If you want to add grommets yourself, find a spot that's clear of wires, etc. on both interior and the undercarriage before drilling.
