Beamerguy Posted August 14, 2017 Report Posted August 14, 2017 BRAND OF SUBWOOFER: SUNDOWN MODEL: SA-12 IMPEDANCE : DUAL 4ohm RMS RATING: 750 RMS Looked at Sundowns website but there box is a little too big for my trunk. Area I’m working with is H-16 W-35 D-38. Running them off a Sundown 1500 Watt amp. The tuning id like to go for is 32HZ
ckeeler11 Posted August 14, 2017 Report Posted August 14, 2017 Can do 16" H x 35" W x 24" D with a port of 14.5" tall x 5" wide x 36" long. This will give a tune of 32 Hz and volume of around 4.15 after displacements.
Joe X Posted August 16, 2017 Report Posted August 16, 2017 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Beamerguy Posted August 20, 2017 Author Report Posted August 20, 2017 Thanks Joe, just one question are the dimesons for the front pieces right? Mocked it up on cardboard and my subwoofer is too big for the cutout.
Joe X Posted August 20, 2017 Report Posted August 20, 2017 Like this, sorry, any other changes, let me know. Enclosure Specifications: Fb = 34 Hz Vb = 4 ft^3 External Height = 16 in External Width = 30 in External Depth = 25 in Port Width = 4 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 12 3/4 x 14 1/2 Back = 30 x 14 1/2 Left & Right Sides: 23 1/2 x 14 1/2 Top & Bottom = 30 x 25 Shared Port Internal Assembly Parts: 2 x Front to Back = 21 1/4 x 14 1/2 2 x Extension = 3 15/16 x 14 1/2
Beamerguy Posted August 20, 2017 Author Report Posted August 20, 2017 Thanks again, will update if anything else comes up. Appreciate all the help.
Beamerguy Posted August 21, 2017 Author Report Posted August 21, 2017 Noticed you didn’t mention anything about 45”s in my design, Do I need to add them as shown in diagram?
