Unexpected Audio Build 2007 crew cab silverado
On 10/23/2017 at 11:01 PM, IxsharpxI said:
so this last pic i was just comparing mounting depth and magnet sizes of front mounting and down facing w3, w6s and w7s.. and then my design for the dual 10" w7 box. i haven't added my port yet as i am still working in Winisd.. but you get the picture. my calculations put me at around 2.5-2.75 cu ft
SOLIDWORKS, so I am not the only one that draws them up in it also.  So what are you supposed to be ding with it instead of speaker boxes.  lol
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
So is that 1 10w7? Should slam. I noticed it likes alot more space than recommended, also tuned to about 30 helped alot too. Slams the lows
05 TL build log SOLD
Yes it is only 1 10 for now. I’m going to save some money back up for a second w7 in the next few months and build the same box designed for two next time. It sounds very goood! My sister has a 10 in the h.o wedge box and mines louder
 agreed my next box will be tuned lower
  • 7 months later...
I have been working on the design for a new box with a second woofer. using WinISD i programmed a 2.5cu. ft box,  32hz, 1.5 x 9x 25.75in port. Recalculate my airpsace and im down to 2.15 cu. ft after all the port and wood space. I'm not sure where i can sacrifice..not to mention the more complexities of the shape of my box how accurate it will be.  i have a box now tuned at 34hz and am wanting to go lower. this design has a much flatter curve then my current design.
Good stuff. I'm about to start an under seat enclosure that's pretty custom for my 2014 2500HD crew cab. Will be ordering the same lift(basically) from LMI. Good to see the attempt at an underseat build that's actually in use and working properly.
I like the new design!
2000 Toyota Solara SEV6, 200 amp alternator, Jensen VX7020, Hifonics American Warrior Taurus X, Hifonics American Warrior Centurion X, JBL Club 6500C, Power Acoustik XP2K-4102, Coustic Power Logic HT-612 in a BP4.
  • Who's Online   0 Members, 0 Anonymous, 1208 Guests (See full list)
