I've been looking for more software to model enclosures with and I found the LA software. It is linked as a .zip folder in a post (#803).
Here is the link to that post: http://www.diyaudio.com/forums/software-tools/220421-transmission-line-modelling-software-81.html
Note: you have to be a member of the forum to download
Once downloaded, extract the file directly to your C: drive. The file path should look like "C:/tline_installer". Open the folder once extracted and run the TransmissionLine.application file.
The owner of the software has approved the distribution of this software (stated in post #809 in the above link). He is currently (as of 9/1/17) trying to find a another site to host the software on as his previous site is no longer up.
This software is awesome. It's fairly easy to use once you kinda figure things out or, better yet, read the help manual. It's only like 18 pages and it's very helpful. This program is very powerful and seems to be accurate so far. Another plus is if you use WinIsd already or another program that has a library of drivers, you can link that library to the program so that you don't have to redo all of your work. I've been playing with it for about 30 minutes and already have the hang of it. I think I will be using this software pretty often. I highly encourage y'all to check it out if you can. If I see he starts hosting it on a site himself I will post that link in the comments.
Also, why is my text being surrounded by a white block when I post?
because you copied and pasted it from somewhere else and didn't "paste as plain text".
Follow my Tweet (Twitter)
Ah, thank you.
