fosgate97 Posted September 29, 2017 Report Posted September 29, 2017 Good evening from Germany.? I want to build a bassbox for a buddy. it is a Rockford T2D412 (the new one). The TSP data I lead you down. The box should have 2 ports, each left and right next to the woofer. The ports, at least according to my ideas, have the dimensions of 30cm high x 7cm wide. The length is given by the frequency. This should be 32Hz. The box should be 70cm wide and 40cm high. Optimally would be 40cm deep. Can one help me in calculating the box, that this comes to 32Hz?? Here the TSP´s: Fs (Hz): 39.9 Re (Ohms): 6.8 Le (mH): 1.72 Qms: 5.31 Qes: 0.67 Qts: 0.59 Vas (Liters): 13.6 Sd (cm2): 430 SPL (dB @ 1w/1m): 84 Xmax (mm): 22.08 Woofer Displacement: 0.177 cu.ft. (5.0 Liters) many many greetings from Germany
WalledSonic Posted September 29, 2017 Report Posted September 29, 2017 Nice avatar haha! I love Cyanide & Happiness Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
