JDTx713 Posted December 13, 2017 Report Posted December 13, 2017 I have a kinetik hc2400 and currently i charge it at 2amps. Would upping that and charging the batt at 3.5amps hurt it, would that be too much voltage or would it be fine
reedal Posted December 13, 2017 Report Posted December 13, 2017 if you can tell me how many volts difference you will have between a 2amp charge and a 3.5 amp charge, i'll give you an answer to your question. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
JDTx713 Posted February 2, 2018 Author Report Posted February 2, 2018 YI dont know i have a Schumacher Battery Extender 12-Volt, 80 Amp Engine Start, 20 Amp Charger/Maintainer and i want to get an NOCO Genius G3500 UltraSafe 3.5 Amp Battery Charger
reedal Posted February 3, 2018 Report Posted February 3, 2018 Alright. you seem to have no idea what the difference between amperage and voltage is, so I'm going to recommend you do some light reading. this will help. www.bcae1.com as far as can you safely charge your kinetic battery using your 12V Charger at 3.5A instead of 2A, that depends on if the kinetic can be safely charged at 3.5A. There should have been some instructions that came with the battery saying "do not charge at a rate higher than....". if you don't have that, check with the manufacturer, do a search for the manual, etc. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
JDTx713 Posted February 7, 2018 Author Report Posted February 7, 2018 Ok i will read on it and thanks
