Amps charging battery
if you can tell me how many volts difference you will have between a 2amp charge and a 3.5 amp charge, i'll give you an answer to your question.
  • 1 month later...
Alright. you seem to have no idea what the difference between amperage and voltage is, so I'm going to recommend you do some light reading. this will help. www.bcae1.com
as far as can you safely charge your kinetic battery using your 12V Charger at 3.5A instead of 2A, that depends on if the kinetic can be safely charged at 3.5A. There should have been some instructions that came with the battery saying "do not charge at a rate higher than....". if you don't have that, check with the manufacturer, do a search for the manual, etc.
  • Who's Online   0 Members, 0 Anonymous, 1499 Guests (See full list)
