fmedina Posted January 11, 2018 Report Posted January 11, 2018 2 minutes ago, Devil Reject said: I re done the dimensions and got the 2ft^3 but the port area per foot is 27.5 in^2. Is that worth worrying about? Seems high to me. I thought I read somewhere that ideally it should be between 12-16. Sorry to be a pain. That 12-16sqin per foot is just a rule of thumb. Really comes down to trial and error and power output like reedal is saying. Try out bass box bro and you can see how it will perform.
reedal Posted January 11, 2018 Report Posted January 11, 2018 37 minutes ago, Devil Reject said: I re done the dimensions and got the 2ft^3 but the port area per foot is 27.5 in^2. Is that worth worrying about? Seems high to me. I thought I read somewhere that ideally it should be between 12-16. Sorry to be a pain. as fmedina said, it's a rule of thumb. if you were only using a single 1400.1 amp, that rule would probably work well for your enclosure. but when using more power you need more port area to reduce loss of output due to port compression. here's a good thread to check out showing testing of different size ports and port compression SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
