Sub box port measuring
AndriusLT
14 minutes ago, AndriusLT said:
Wiring to 2 ohm and sending 600W RMS each would be the same thing yes?
if you have 2 single 4 ohm subs youll wire to either 2 or 8 at the amp.  that amp is rated to do 1200rms @ 1 ohm, 800rms @ 2 ohms, and 500rms @ 4 ohms.
based on what i found, that specific model of sub is a single 4 ohm, 275rms handling sub.  so that means youll be wiring to 2 ohms at the amp, sending approx 800 watts to the subs.
adjusting for the power output, we're closer to the minimum required port area, but still about 6 sq in off.  from the minimum.  providing torres is accurate enough.
this might be starting to get out of my realm of knowledge/understanding so if someone else wants to jump in and offer some advice, it'd be super helpful :)
  • Who's Online   0 Members, 0 Anonymous, 4323 Guests (See full list)
