jessdabest77 Posted January 23, 2018 Report Share Posted January 23, 2018 Hey guys Im trying to install a Viper Responder 350 2 way security system 3305v alarm in a 1999 Lincoln Town Car. No remote start but trying to figure out what all needs to be done to install it. i have reschearched it and I dont understand the Fords PAT Anti-theft Transporder system. I was hoping for help installing this alarm hopefully from start to finish. Thanks guys. Link to comment Share on other sites More sharing options...
slowfkncar Posted January 23, 2018 Report Share Posted January 23, 2018 2 hours ago, jessdabest77 said: Hey guys Im trying to install a Viper Responder 350 2 way security system 3305v alarm in a 1999 Lincoln Town Car. No remote start but trying to figure out what all needs to be done to install it. i have reschearched it and I dont understand the Fords PAT Anti-theft Transporder system. I was hoping for help installing this alarm hopefully from start to finish. Thanks guys. Good news is, you don't need to mess with the pats transceiver for a basic viper install. All you need would be, 12v - yellow or lt.green/violet (+ @ column) Ign - white/yellow (+ @ column) Lock - pink/yellow (+ @ driver door harness) Unlock - pink/lt.green (+ @ driver door harness) Parking lights - brown (+ @ LCM) Door trigger (dome light) - black/lt.blue (+ @ LCM) Trunk trigger - Brown/white (- @ LCM) Lighting control module is on the right hand side of steering column. Link to comment Share on other sites More sharing options...
jessdabest77 Posted January 24, 2018 Author Report Share Posted January 24, 2018 Oh wow,so the PATS Transciever is only for remote starts? Also no relays or diodes are needed cause on some sites it says to put them on the lock/unlock and parking lights? And thank you for your help really is useful Link to comment Share on other sites More sharing options...
slowfkncar Posted January 24, 2018 Report Share Posted January 24, 2018 1 hour ago, jessdabest77 said: Oh wow,so the PATS Transciever is only for remote starts? Also no relays or diodes are needed cause on some sites it says to put them on the lock/unlock and parking lights? And thank you for your help really is useful Yes it's an engine immobilizer, not needed for keyless entry. You only need a relay to hook up the trunk release & you only need diodes if you prefer to use the door pins instead of the dome light for door trigger. Link to comment Share on other sites More sharing options...
jessdabest77 Posted January 24, 2018 Author Report Share Posted January 24, 2018 Thank you soo much for your help. You made this guy smile☺️ Link to comment Share on other sites More sharing options...
