since my car didn't come factory with them I want to install the oem kit..problem is the kit has all the wiring but it uses a push switch .so therefore I either have to cut them on manually or somewhow wire them to come on when my lows cut on.but my lows are always on...can I tap into my 12volt charger in my console and use that for the power for the fog lights..that way I can keep the switch pushed in but will only come on when my ignition is on.....or just go ahead and spend another 50-60 and get the headlight switch that cuts them on like factory....
without headlight switch  https://www.ebay.com/itm/2piece-NEW-FOG-LAMP-LIGHT-KIT-fit-For-Nissan-Sentra-sylphy-2016-Y-/262884145159?_trksid=p2349526.m4383.l4275.c10
with https://www.ebay.com/itm/192291775827
if you have an aftermarket radio, use the illumination wire to trigger a relay to turn on your fog lights. then they'll just come one when you turn your interior lights for night driving.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   0 Members, 0 Anonymous, 1505 Guests (See full list)
