wiring 2 dual voice 4ohm speakers
happs subi
From what i have seen most people wire 2 dual voice 4 ohm subs like in the first picture to get 1 ohm. 2 wires coming from 1 sub going to the amp.
 was wondering what would be the outcome of the two other pictures? with 1 neg from 1 sub, pos from the other sub? or 1 pos and 1 neg from 1 sub, and 1 pos 1 neg from the other going to the same amp?
First one is voice coils in parallel / subs in parallel and gives you a final impedance of 1 ohm.
Second one is the same thing, only you are getting the positive from a different place, but since they are all connected to each other it's the same as no. 1.
Third one is the same thing again, only with 2 runs of positive and negative (which you don't need).
Your options are these:
1. voice coils in parallel / subs in parallel -> 1 ohm (parallel is positive to positive and negative to negative; series is positive to negative and the other positive to the other negative)
2. voice coils wired in series / subs wired in parallel -> 4 ohm
3. this would be everything wired in series which would give you a 16 ohm final impedance. You don't need that.
  • Who's Online   0 Members, 1 Anonymous, 2017 Guests (See full list)
