guero187 Posted April 1, 2018 Report Posted April 1, 2018 ok so i have a zv5 12 and its going to be powered be a scv 3000 in a 2014 Silverado. plan on doing big three up grade and a d3400 battery. first off i want to make sure this is going to be the right battery for my use and second is am i going to need to upgrade my stock alt? thanks for any help
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 What is the stock alt's output? Are you running a mids & High amp?
guero187 Posted April 1, 2018 Author Report Posted April 1, 2018 the stock alt is 150 amps. and as of right now , no mids/high amp
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 There are wattage to amperage calculators you can google. Stock alt and upgraded battery your possible maxed out on your electrical and if you plan a mids & highs amp down the road another battery wouldn't hurt. What ohm load and wattage will the amp be putting out?
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 Found this.https://www.rapidtables.com/calc/electric/watt-volt-amp-calculator.html
guero187 Posted April 1, 2018 Author Report Posted April 1, 2018 1 ohm not sure the wattage. so if just went ahead and bought a ho alt and went with that would it still be recommended in getting a 2nd battery?
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 SUNDOWN website rates that amp @ 3000 watts in 1 ohm.
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 I am not sure if i am using the calculator right but it comes up at 200+ amps at 3000 watts in 1 ohm.
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 XS D3400 looks to be good from 2500-4000 watts. From what there website shows.
bcbrassard Posted April 1, 2018 Report Posted April 1, 2018 I think your stock alt would have a tough time keeping the battery charged. I would looking into a alt upgrade and second battery for future upgrades. I am not the most knowledgeable person on this website and others with more experience will chime in. What i do know is the electrical is the heart of the system and hard to go overkill in my opinion. I run a little over 3500 watts total and have upgraded alt and 4 battery's. I just didn't want to half ass it so i know doing it right the first time pays dividends and protects the equipment. I have about 2 grand into my electrical. So i know it's not cheap but is done right.
