Ernest Posted June 17, 2018 Report Posted June 17, 2018 What do I need to run a scv 7500? mec 270 and 2 excess power d7500 good enuff? what size alt would you recommend and how many battery’s would you recommend?
Kyblack76 Posted June 18, 2018 Report Posted June 18, 2018 what nominal load you thinking about wiring to ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Ernest Posted June 18, 2018 Author Report Posted June 18, 2018 .7 on subs. will be 2 team fi’s Or 2sp4’s complete rebuild. What my first priority is electric maby I could bump up alt to a 320 or 370 and front batt will prob be exes as well. Just worry about running a 7500 at full tilt for a long time. It will be a daily setup, even kicking around the idea of a dc 7500
Ernest Posted June 20, 2018 Author Report Posted June 20, 2018 Ok, after some digging around the biggest alt I can find is a 270. How many d7500’s do I need to keep things safe on a scv 7500, wired to 1ohm at full tilt?
AlpineNut Posted June 20, 2018 Report Posted June 20, 2018 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n
