15" SP4 v1 Enclosure help
It all depends on the size of the 45's... 4 ea 3" 45's and a dowel, all 12.5" tall = .08ft3 roughly Thats 2.12 2.12 x H for a set (2) of 3"
                                                               ... 4 ea. 4" 45's and a dowel, all 12.5" tall = .13ft3 roughly That's 2.86 x 2.86 x H for a set (2) of 4"
Dowels are easy... same as finding the area of a circle then volume of a cylinder... Pi X radius2 x Length. In this case using a 1.5" dowel it's 1.76 .(75 x .75 x 3.14) X 12.5 (L)... that ends up as .012ft3
Helps a bunch when you've done it awhile and the values are automatic... lol
Man good shit. I need to get off this mentally lazy spell haha. I swear I've been guessing displacement for my bracing ( scientifically of course ??). I round down tho so... LMFAO!
how would port area requirements change if I went aeroport? still 15-17cuft per cube?
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
Ok so I think this should work out pretty good I did calc's with and without bracing. I will add that if needed. This double baffle should hold up just fine. Im using maple.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Not bad... see post 21 for bracing displacements... a touch low on port area on your power but you'll probably never notice... Nike it!
  • 9 months later...
Thanks for all the info last year ya'll. I have decided to rebuild, go with more port area, box sounds great just time for a change. Did decent numbers with this setup but peaking higher then I would like. I am looking for some more suggestions, would like to really feel the lows. I swear this corolla his tough af to get loud. Now weighing my options between aeroport and slot port. I can fit 14.75Hx35Wx26D max. I have thought about port facing back the width of the box but maybe im missing something. Cant achieve port area and tuning that I want. Fi recommended 65-75in I'm shooting for 32hz or lower. prefer lower if possible. Thanks for any info guys!
Still on AQ3500.1, dual input version
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
  • Who's Online   0 Members, 0 Anonymous, 1616 Guests (See full list)
