Hellbilly429 Posted June 30, 2018 Report Posted June 30, 2018 Also, pencil out your port opening, rough cut the hole with a jigsaw, router the lines out using a rabbiting bit against the walls, then trim the corners out carefully with the jigsaw. If you want video tutorials, Mark from Car Audio Fabrications has fantastic how-to videos and will show you best practices. 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
Jahlg64 Posted June 30, 2018 Author Report Posted June 30, 2018 8 hours ago, Hellbilly429 said: Also, pencil out your port opening, rough cut the hole with a jigsaw, router the lines out using a rabbiting bit against the walls, then trim the corners out carefully with the jigsaw. If you want video tutorials, Mark from Car Audio Fabrications has fantastic how-to videos and will show you best practices. Can' I just adjust the size of the panel to allow for the port opening instead of covering and then removing material?
Hellbilly429 Posted June 30, 2018 Report Posted June 30, 2018 Absolutely! I just like the look of the finish better when done the way I described. Personal preferences, but both get the job done. 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
Jahlg64 Posted June 30, 2018 Author Report Posted June 30, 2018 12 hours ago, Hellbilly429 said: Cool
