T40001bd What Size Alt And How Many Batterys Do I Need
Crazystang306
I just got a T40001bd for Cheap! ($825) It was benched at 4785 watts. birth date is 3-17-08. I was wondering how many Amp alt am i going to need and how many batts.
1995 Tahoe 2dr stock 105Amp Alt
I Plan on running Two BTL's off of it .
Any help Would Be awesome!! Thanks
I would say get a 300 amp and a dual bracket, keep you stock alternator and just add the 300. Maybe a missing link module to keep them working right. For batterys im not sure maybe 2 d3100's
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
what he said
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Go the biggest you can afford, that amp will need it. Plus you will have room for more in the future :0
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
I would say 2 200 amp alt would be fine, 3 would be overkill (means perfect).
2 batterys would be fine, 3 would be overkill (again perfect).
If you plan on playing with engine off, 3 would be fine 4 would be overkill (like i said perfect).
The amp full tilt on music should be in the 400A range (350-450).
uh you dont need 2 alts for that amp
I have a single 300amp and 5 batteries powering 2 t4k and a t8004
a 240-260amp alt and 2 strong batteries would be good
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
