Daddy_ Posted August 5, 2018 Report Posted August 5, 2018 Can JoeX build a box for 2 10" JL Audio W6v3 running off 1200RMS tuned to 34-35hertz. Not sure what the sweet spot for these subs are but JL recommends 1.5 net volume which I think is too small. Height 13. Width 30. Deep 20. If you need to you can go 25 deep. Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
Joe X Posted August 5, 2018 Report Posted August 5, 2018 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
